Results 1 to 8 of 8
    55xtrail55's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default is there a work around....
    Hi,
    I have dropped my galaxy s4 and smashed the screen and glass, the phone still turns on, and connects to wifi I believe, but obviously the touch screen isn't working. When I connect it to my laptop, I see the phone icon appear, but when i double click it, it says this folder is empty...if I right click it and select import it says no photos or videos found. I thought about connecting it to my TV, but I have the swipe screen pattern security enabled, so figure this would be futile. I have all my photos backed up to dropbox, but i didn't sign my phone into Samsung link, so I can't retrieve stuff that way...what I really need are my contacts...any suggestions?
    Thx
  2. #2
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Default Re: is there a work around....
    Welcome to AC
    Unfortunately, you won't be able to access any folders or files if your phone has a PIN setup. There might be a workaround if you're rooted, but I'm guessing you aren't. Did you not have your contacts synced with Google Plus either?
    55xtrail55's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by UJ95x View Post
    Welcome to AC
    I don't think so, but might have done, how would I tell? where would I look please?
    55xtrail55's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It seems that within samsung link I can unlock the screen, does this mean I could connect the phone to my tv? I have just unlocked the screen, and my pc is now finding all the photos on it, but that doesn't help me get my numbers lol
  5. #5
    raptir's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If you had a Gmail account linked to your phone (which you need for the play store) your contacts should be saved to your Google account. Log in to your Google account at contacts.google.com and you should be able to get your contacts back.
    UJ95x likes this.
    55xtrail55's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I can now view all the folders on my phone via my laptop, where are the contacts stored to / saved? so I can copy them over please?
  7. #7
    raptir's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by 55xtrail55 View Post
    They're not saved to the storage that's accessible via USB. I would install Kies and use that to extract your contacts.
    Kies | SUPPORT | SAMSUNG
    I don't know if there's any setup needed on the phone...
  8. #8
    B. Diddy's Avatar
    Posts
    Global Posts
    77,765 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Check out this thread and see if it helps: A quick guide to accessing a locked phone with a cracked screen
  1. Replies: 32
    Last Post: 08-30-2015, 02:02 PM
  2. Replies: 51
    Last Post: 08-25-2014, 06:45 PM
  3. Samsung Apps is a nuisance
    By Rowdee1 in forum Samsung Galaxy S II
    Last Post: 08-15-2014, 08:43 AM
  4. Smartphone Newbie (Dumb is more like it) Lol
    By vtrvrgal in forum Android 4.4 KitKat
    Last Post: 08-13-2014, 12:35 PM
  5. Google play store app unfortunately spec working?
    By erwaso in forum Ask a Question
    Last Post: 08-12-2014, 07:10 PM
