Results 1 to 3 of 3
Like Tree2Likes
  • 1 Post By srkmagnus
  • 1 Post By Rukbat
    Nigel Huang's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Battery Drain
    Hello, I'm running Android 4.4.4 on Nexus 5 and I have Battery Doctor, Cut the rope, Piano Tiles, Paper Camara, and Swiss Army Knife installed. When I got the phone I'v been having serious battery problems. Apparently Google Services is using 78% of the battery. Location services is on device only. I just finished charging to 100% and when I unplug 1 minute later it loses 2%. Please help me fix..
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,762 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Default Re: Battery Drain
    Can you post a screen shot of the battery usage screen when the battery drops below 50%? Also provide the screen on time screen shot so we can see what's happening.
    You may need to factory reset them add applications back slowly to identify the problem. First, let's see if we can identify the culprit :-).
    B. Diddy likes this.
  3. #3
    Rukbat's Avatar
    Posts
    Global Posts
    22,834 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Modified Stock 4.4.2
    Quote Originally Posted by Nigel Huang View Post
    Many phones report 100% charge when the battery itself hasn't fully charged (due to the method of measuring charge state and the fact that the charger is adding voltage to the measurement) and as soon as you disconnect the battery it reports almost, but not quite, fully charged. When that happens, plug the charger back in for an hour or so. Eventually, the charge state will recalibrate (unless the phone is defective - they you'll never get more than 98% charge).
  1. samsung galaxy note 3 battery
    By hamzahmalas in forum Samsung Galaxy Note 3
    Last Post: 08-16-2014, 06:33 PM
  2. Strange Battery Issue with Samsung Galaxy S3
    By cindylike24 in forum Verizon Galaxy S3
    Last Post: 08-15-2014, 09:50 PM
  3. samsung galaxy s3 battery draining fast
    By Mohammad Shebaro in forum Ask a Question
    Last Post: 08-13-2014, 01:13 PM
  4. galaxy note 2 battery
    By Rafic Beydoun in forum Ask a Question
    Last Post: 08-13-2014, 12:43 PM
  5. Phone factory reset after battery died
    By fratellojake in forum Ask a Question
    Last Post: 08-13-2014, 11:41 AM
