Results 1 to 3 of 3
    Default Not registered on the network and upgrading fom Jelly Bean to another Kit Kat or ano.
    Good morning folks,
    I recently bought 2 Samsung trend lites with jelly bean 4.1.2 installed. I am haveing problems with it and I have seen that I should upgrade the software. JB is now up to date but I do not know how "changing" from say Jelly Bean 4.1.2 to say Kit Kat or any other version works.
    I've searched "is it safe to do so" no luck. I am begining to realise that the phones I purchased are in fact old models and cant be upgraded to a different verion of Android. If that's the case I have learnt another lesson. No one tells you that and you can do nothing about it. The phone is legally working. The software may have a fault but no-one takes responsibility.
    So what can I do?
    The problem I also have is "Not registered on the network" if I dial a number. I've seen various solutions and each are for the technically brilliant geeks of which I am not. None of the solutions I read about are simple and this is just not correct. I also find it annoying that the manufacturers of these phones give no help.
    I feel I am stuck with a phone that is slow and buggy.
    Is there anyone who can give me a simple fix for the No network bug and tell me what I can do or even if it is worth doing with JB toKK?
    Thanks in advance to anyone who can reply. Henry
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,673 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Not registered on the network and upgrading fom Jelly Bean to another Kit Kat or ano.
    Did you buy these new or used? Are they compatible on your network?
    New/ They are working well with orange France
  1. What is the current way to change play store location?
    By bazgrant in forum Google Play Store
    Last Post: 08-25-2014, 11:33 AM
  2. To come back to Android or not?!
    By Aimes_D in forum Ask a Question
    Last Post: 08-19-2014, 12:12 PM
  3. Help! I may have lost my photos on my micro SD card!
    Last Post: 08-18-2014, 04:40 PM
  4. Unable to transfer -apps-
    Last Post: 08-16-2014, 07:00 PM
