1. Hal Eagar's Avatar
    So there are tablets out/coming that look great. Accept the price and contracts, or lack of Market.
    But I know a lot of Android devices can be gotten on ebay, and I'm wondering if that might be a better solution for me especially since I really only need a mid range device. And no cell or data plan at all.
    But a 2.2 device with adobe flash would be crucial, I've got a G2 and two toddlers. Now there are lots of fun things for a toddler to do on the phone but that leads to three problems.
    A) I can't use the phone for useful things like phone calls, or checking the shopping etc. list if they have it.
    B) There are two of them and I only bought one G2.
    C) It kills the battery and that also gets in the way of useful things like phone calls.
    anyway though flash seems a tad wonky on the G2 it's still a big carrier of toddler content. But rooting and loading a froyo rom is no problem.
    So any advice as to what cheap device I ought to look for on ye old ebay?
    I'm new to Android and not sure what's what with the plethora of devices.
    11-02-2010 09:37 PM
  2. corydunbar's Avatar
    you can get a droid eris on ebay pretty cheap ~ $110. and then you can root it and put kaosfroyo on it. [ROM]KaosFroyo V38 [10/28] [FROYO] - xda-developers
    11-02-2010 09:57 PM
