Results 1 to 4 of 4
    Default
    It doesn't happen always, but when it happens, it's always when the system is starting, when the apps are starting and being granted root permissions, etc. If I don't do anything, is fine, but If I unlock my screen while the apps are loading on startup and start to open some apps, it reboots(not always). I don't know If it overloads or something, but aLogcat doesn't record anything after the system reboots. I've already used Boot Manager to disable some apps from starting, but the problem persists. It's a Moto X 4.4.4 Stock and I never had this problem before. I belive t's a Xposed Module, but I want to know which one is.
    Thanks.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,740 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Device rebooting sometimes on system startup (with kernel message).
    Couple questions:
    1. Did you root your device and install Xposed?
    2. What was the link you were trying to post? A screenshot?
    Quote Originally Posted by Golfdriver97 View Post
    Couple questions:
    1. Yes
    2. No, it was a dropbox link with the kernel message in a PDF . This 10 post limit is killing me. The kernel log is long, I can't post it here directly. But If I can't post the link to makes things easy, I guess it's my only alternative.
  4. #4
    Posts
    Global Posts
    32,740 Global Posts
    Carrier
    Quote Originally Posted by alex91s View Post
    1. Yes
    OK. A couple choices here: A reset should clear out all the modifications Xposed made, or if you have a custom recovery, you can restore the Nandroid before you made the changes.
  1. I need help with me phone
    By Essam H in forum LG G2
    Last Post: 08-18-2014, 04:19 PM
  2. Can't view files on my windowns 8
    Last Post: 08-18-2014, 04:30 AM
  3. Galaxy S5 downloading pictures on its own?
    By illegally_bl0nde in forum Ask a Question
    Last Post: 08-17-2014, 09:54 AM
  4. need assistance with 900F
    By osrs360 in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 08-17-2014, 09:52 AM
  5. Replies: 2
    Last Post: 08-17-2014, 07:42 AM
