Hi,
Today I noticed that my nexus 5 was crazy hot when charging (52.7ºC according to CPU-Z), I turned it off, waited for it to cool down a bit, and then turned it back on. then I went to setting->battery to see if there was any buggy app that was behaving abnormally, but found nothing out of the ordinary. but I found through CPU-Z that the cpu load was pretty high, I went to settings->apps to see which apps were open and to my surprise android was simple opening random apps, closing it and doing it again. just look for yourselves:
youtu.be/s9ytS0Fu_Wo
(sorry for the vertical video)
I recently installed duolingo and wikipedia apps, but I doubt that they are the culprit. This had already happened before, but a simple restart fixed the issue and I just carried on without worrying about it. but now, no matter how many times I restart, this issue persists.
This has really being an issue to me because my phone is now pretty much useless, the battery drains really fast and the phone is too hot to even keep it in my pocket.
I really appreciate any help anyone can provide. Thanks
