1. Sizzers's Avatar
    EWhen I reboot my phone instead of going through the routine of SIM lock PIN then phone lock PIN, it just goes straight to the phone lock with no network connection.
    This firstly occurred at work today when distractedly I ended up in "Safe mode", which doesn't work for me in any case as there's a bug or whatever somewhere which is by the by. So after rebooting a warning triangle and exclamation mark was showing in the status bar where it said...."Your selected network (3) is not available", 3 being my network in the UK. I did the obvious: removed the SIM, gave it a wipe, remounted it and hey...network back!
    I was a little concerned that perhaps the pins in the SIM card housing may be faulty so to check I rebooted my phone this evening after work with exactly the same result and the same solution. Totally bizarre, so anyone have any ideas?
    Thanks in advance,
    Malc.
    Posted via Android Central App on my XT1032
    Edit: Forgot to add I have wiped the cache.
    08-18-2014 04:22 PM
  1. anyone have the new playstore
    By supert1020 in forum LG G2
    Last Post: 08-25-2014, 05:46 PM
  2. i can't turn off a wireless my phone verizon samsung note 3
    Last Post: 08-25-2014, 01:24 PM
  3. Just had a private # call my phone, and never left voicemail.
    Last Post: 08-21-2014, 07:34 PM
  4. is your phone rooted or not?
    By TurkXtreme in forum LG G3
    Last Post: 08-18-2014, 09:31 PM
  5. Two dialers answering phone
    Last Post: 08-18-2014, 03:29 PM
