1. Daniel.Lynch's Avatar
    So I've got a couple micro USB cables that are fully functional on the electronic end, yet the plug doesn't seem to "lock" into place in my phone. I'm guessing its those two little things that stick up on the top?(depends on who you ask?) side of the plug. Anybody figure out how to pop these puppies back out or repair these cables? Hate to toss a cable if I can fix it.
    08-19-2014 10:36 PM
  2. hiredgun's Avatar
    Not sure exactly what you mean, but if they are not fitting tightly on the end that plugs into the phone, I have found that wrapping the tip with Scotch tape will do the trick a lot of times. Try just going around once, and if it's still lose you can try wrapping it twice. If it's a loose connection you are talking about, this should do it.
    08-20-2014 02:55 AM
  3. raptir's Avatar
    I really wouldn't recommend this, since you could end up gunking up your MicroUSB port and causing your phone to no longer make a good connection via USB. That's much harder to repair. If it comes down to this, spend the $3 on a new MicroUSB cable before you start sticking tape into your phone's USB port.
    As far as repairing the cable itself, it can be tricky. The little prongs you're talking about look like hooks but they are actually solid "wedges." Your best bet is to try getting behind them by going in through the "top" (the end of the slit the prongs are in that is closest to the phone end) with a very thin needle.
    Honestly though, I would just spend the $3 and buy a new cable from Monoprice.
    Premium USB to Micro USB Charge & Sync Cable 6ft- Black - Monoprice.com
    The "premium" cables are worth the extra cost. The only problem I've ever had with a USB cable is what you're describing (the prongs giving way and the cable not staying in the phone). That usually happens to me after about a year. I've had the premium cable for two years and it is still going strong. Either way, they have a lifetime guarantee and will replace the cable (including for this issue) without charging shipping.
    08-20-2014 09:30 AM
  4. Daniel.Lynch's Avatar
    I've got plenty of extra cables, I just didn't want to throw this one away. I tried pulling them back up with a needle and it seems to have worked! I actually have that monoprice cable lol.
    08-20-2014 05:08 PM
  5. raptir's Avatar
    Great. Like I said, Monoprice will replace them for this issue (I ran into it with the non-premium cables). I just told them it was no longer sticking into my devices, and that I had tried with multiple devices, and they sent me a new one without having me return the old one.
    08-20-2014 05:11 PM
  6. Daniel.Lynch's Avatar
    Yeah, the monoprice premium cable I've got works great, its just the cable that came with my DNA that is messed up.
    08-20-2014 05:15 PM
  7. raptir's Avatar
    Ohhh okay, sorry. I thought you meant the monoprice cable was the one that failed.
    08-20-2014 05:54 PM
  8. Rehbar Sayyed1's Avatar
    One Of The Easiest Way To Fix (In-Depth) Click The LInk Below
    Thank Me Later
    12-28-2016 11:23 PM
  1. Ethernet Cable
    By codyoehl in forum Ask a Question
    Last Post: 08-21-2014, 10:36 AM
  2. External battery pack for S5 which has charging cable attached?
    By atomarchio in forum Samsung Galaxy S5 Accessories
    Last Post: 08-19-2014, 09:10 PM
  3. LG G3 Going to micro SD?
    By Murph5150 in forum LG G3
    Last Post: 08-19-2014, 06:28 PM
  4. Replies: 1
    Last Post: 08-19-2014, 04:41 PM
  5. Best USB Charging Cables
    By fsfty in forum LG G3
    Last Post: 08-19-2014, 11:24 AM
