Results 1 to 5 of 5
    Default LG Phone and Samsung Gear Fit
    i have an LG G Pro 2 Phone and my brother does'nt need his samsung gear fit.
    and yes i want to take it, BUT.. is there a possible way that i can use/connect my LG phone to this Samsung Watch?
    well they have different Brand.
    is there any possible way?
  2. #2
    Default Re: LG Phone and Samsung Gear Fit
    It's doable, but not everything will work.
    How to use Samsung’s Gear Fit smartwatch with other Android devices | 9to5Google
    Also make sure that he updates it fully from his phone before you take it.
    Quote Originally Posted by raptir View Post
    thanks, but if i use it, then when theres on update, can i give it to him to update it then take it back again?
  4. #4
    Quote Originally Posted by Lyle DylandY View Post
    You should be able to, but I'd be careful with respect to not getting your data crossed.
    by the way, he just use it once though, and how to update the samsung gear fit? it says in the video that it has to be updated before connected to other android devices, so how can you update samsung gear fit? well my brother uses S4. how cana he update it? any step/s?
  1. wifi hotspot for my S5 with Verizon and unlimited data
    By Ed Ke6bnl in forum Ask a Question
    Last Post: 08-26-2014, 08:06 PM
  2. Replies: 3
    Last Post: 08-23-2014, 02:01 AM
  3. 2 issues: Connecting to wifi and keyboard
    By memphislawyer in forum HTC One M8
    Last Post: 08-22-2014, 04:12 PM
  4. Samsung S3 battery drain fast
    By Wan Mohd Nazman in forum Ask a Question
    Last Post: 08-22-2014, 10:14 AM
  5. Replies: 1
    Last Post: 08-22-2014, 09:44 AM
