1. barth2's Avatar
    I'm running cm 11 on nook hd plus and latest version of ES Explorer. I have root browser turned on in ES. I can browse root. But I'm trying to chmod /system/fonts to 777 and it says operation fails.
    Weird thing is, I did this once successfully. I don't know what changed.
    Yes I know there are font changer apps, but I'm trying to change some fonts other than roboto-regular.ttf
    08-22-2014 09:19 PM
  2. wizzrah's Avatar
    Hello. Have you tried another file explorer other than ES File Explorer? And just to confirm, you have root correct?
    08-22-2014 10:39 PM
  3. barth2's Avatar
    Thanks. I tried astro and root Explorer but I didn't even see a way to do chmod. Maybe because it's the free version?
    Anyway, I tried using terminal. I did this
    su
    mount -o remount,rw /
    cd /system
    chmod 777 fonts
    I still got "read only file system."
    What do I need to do?
    08-22-2014 11:58 PM
  4. barth2's Avatar
    I figured it out. In ES, turn off root Explorer, exit app completely. Run apps and turn on root Explorer. Now it will give a dialog and I'll have option to mount system folder as rw
    08-24-2014 02:59 PM
  1. Galaxy S5 won't communicate with Ford Sync
    By new android user in forum Samsung Galaxy S5
    Last Post: 05-28-2015, 11:56 PM
  2. Can't receive text w/photo from Samsung Galaxy s4
    By 510bettina in forum HTC One M9
    Last Post: 09-09-2014, 02:22 PM
  3. Issues with file browsing on desktop
    By aledelcastle in forum HTC One M8
    Last Post: 08-22-2014, 06:50 PM
  4. Nabi 2 Pattern Lock Forgotten Can't Factory Reset
    Last Post: 08-22-2014, 04:46 PM
  5. Group Messaging with iPhone Users
    Last Post: 08-22-2014, 02:50 PM
