Results 1 to 4 of 4
    Default Can't chmod with ES Explorer
    I'm running cm 11 on nook hd plus and latest version of ES Explorer. I have root browser turned on in ES. I can browse root. But I'm trying to chmod /system/fonts to 777 and it says operation fails.
    Weird thing is, I did this once successfully. I don't know what changed.
    Yes I know there are font changer apps, but I'm trying to change some fonts other than roboto-regular.ttf
  2. #2
    wizzrah's Avatar
    Posts
    Global Posts
    4,045 Global Posts
    ROM
    Phoenix 1.6 Sense 5 4.2.2
    Default Re: Can't chmod with ES Explorer
    Quote Originally Posted by barth2 View Post
    Hello. Have you tried another file explorer other than ES File Explorer? And just to confirm, you have root correct?
    “Knowing how to think empowers you far beyond those who know only what to think.” - Neil deGrasse Tyson
    In September of 2014 comes the greatest tool to modify almost any HTC phone. Unlock bootloader, flash recovery, root, and more. Open sourced, powerful, powered by the cloud via SSL, and best of all, it's 100% free. All built by me. Get ready to rock!
    Thanks. I tried astro and root Explorer but I didn't even see a way to do chmod. Maybe because it's the free version?
    Anyway, I tried using terminal. I did this
    su
    mount -o remount,rw /
    cd /system
    chmod 777 fonts
    I still got "read only file system."
    What do I need to do?
    I figured it out. In ES, turn off root Explorer, exit app completely. Run apps and turn on root Explorer. Now it will give a dialog and I'll have option to mount system folder as rw
  1. Can't receive text w/photo from Samsung Galaxy s4
    By 510bettina in forum HTC One M9
    Last Post: 09-09-2014, 02:22 PM
  2. Galaxy S5 won't communicate with Ford Sync
    By new android user in forum Samsung Galaxy S5
    Last Post: 08-23-2014, 07:55 AM
  3. Issues with file browsing on desktop
    By aledelcastle in forum HTC One (M8)
    Last Post: 08-22-2014, 06:50 PM
  4. Nabi 2 Pattern Lock Forgotten Can't Factory Reset
    Last Post: 08-22-2014, 04:46 PM
  5. Group Messaging with iPhone Users
    Last Post: 08-22-2014, 02:50 PM
