1. gargavf's Avatar
    I have a Nexus 4. I used adb and unlocked it, and flashed the recovery boot loader to CWM,
    and I have rooted it. (pointed the CWM recovery to a supersu ZIP (not sure if that then involved a flash?)
    and so any app can run the su command and make that request which is managed by the supersu program..
    so i've got that far.
    But now I want to see the battery saving capabilities.
    I read that Incredicontrol is good for that, but it require that I flash my kernel..
    A)with what file and what adb command? - I am on Android 4.2.2 not sure if that makes a difference?
    B)would that wipe anything?
    C)would that change anything in the android GUI?
    TIA
    08-24-2014 06:53 AM
  1. Issue with 64GB SD card in Samsung Galaxy S4 I950
    By uzair007 in forum Samsung Galaxy S4
    Last Post: 08-30-2014, 10:02 AM
  2. Replies: 8
    Last Post: 08-28-2014, 10:00 PM
  3. Settings Won't Save
    Last Post: 08-24-2014, 06:32 AM
  4. Help with Knox Airwatch and root
    Last Post: 08-24-2014, 12:35 AM
  5. My S4 suddenly turn green screen
    Last Post: 08-24-2014, 12:30 AM
