1. Juan Pagnutti's Avatar
    Hello Everyone!.
    I am a IOS user from first iphone. Last year was liked to switch to a M7, but the camera doesnt liked to me, and the incompatibility to the mac ( usb host problem ) was determined to go back to my iphone 5.
    Now i have an iphone 5s. Really like to switch to android. i dont care the iphone 6, is the same like 5s, but bigger.. i have an ipad and it is very boring.
    So. I like to switch to android but i dont know wich device get.
    Note 3, has some problem?, is the best?.
    S5, the people say that there are many problems of laggy on forums
    G3, too laggy (say people on forums)
    Z2, it has problems with 4k recording. i dont know if it have more problems
    M8, the camera 4mpx, is really bad, if you like do zoom,
    Z2 and m8 are from aluminium and this is very good for me.
    Note 3 has bigger screen, good.
    G3 good screen.
    S5, i dont know, is the most speedest of all of this?
    Thank you all!
    08-26-2014 10:25 AM
  2. UJ95x's Avatar
    Welcome to AC
    It really comes down to your preferences. If you are a fan of Samsung's skin, you can go with the S5 or Note 3 depending on what size you'd be most comfortable with.
    If you like the front facing speakers of the M8, then obviously that would be the only choice.
    The G3 is also great. It is not laggy. The only issues I have heard is the battery life in comparison to the other flagships isn't great.
    Have you gone to a store to play with all of these devices?
    Sent from my Galaxy S4 running SlimKat 4.4.4
    08-26-2014 10:59 AM
  3. Juan Pagnutti's Avatar
    Hi!.
    Yes, i gone to the store, all are great there!. jja, the problem is 1 month late of use.
    The z2? I very like the design, (maybe becuse is very similar to iphone)... but the aluminium is very good.
    M8 camera are very bad
    samsung pastic bad
    08-26-2014 12:13 PM
  4. UJ95x's Avatar
    Hi!.
    samsung pastic bad
    So no M8, no GS5 or Note 3. G3 vs Z2? Both are great. If you like the looks of the Z2, I'd suggest that
    08-26-2014 12:24 PM
  5. Juan Pagnutti's Avatar
    Sure z2?. there isnt problems with the screen on external conditions?. I readed that the water proof isnt good and the updates of sony are very bad
    I readed too that it put very hot!!
    08-26-2014 12:28 PM
  1. Samsung Note Pro SM905 Queries
    By toprobroy in forum Ask a Question
    Last Post: 10-11-2014, 03:04 AM
  2. Do the GS5 from Sprint work on Straight Talk?
    By kbanksta in forum Samsung Galaxy S5
    Last Post: 08-27-2014, 05:02 PM
  3. not connecting to wifi
    Last Post: 08-26-2014, 11:16 AM
  4. my Samsung note doesn't start up
    Last Post: 08-26-2014, 10:34 AM
  5. transfer music from laptop to samsung galaxy S4
    Last Post: 08-26-2014, 10:28 AM
