1. preppystud's Avatar
    i am using a refurbished "new" nexus 7, it is working fine so far. it is better than the new one, the new one was rebooting itself randomly often.
    i am considering buying a refurbished samsung 10 inches tablet, any comments?
    08-31-2014 07:55 PM
  2. srkmagnus's Avatar
    Refurbished units go through pretty tough testing to make sure everything is in working order. I would say it's a good bet the next one you purchase would be just as good. Regarding the original, new device rebooting, that may have been a unique case. Which does happen, so don't let that leave a sour taste for future devices. Either way, you'll definitely find good deals on refurbished units.
    Let us know if you pickup a refurbished Samsung 10-inch tablet and how you like it compared to the Nexus 7.
    08-31-2014 08:42 PM
  3. ShaggyKids's Avatar
    You might have a look at Swappa.com. I've purchased several phones and tablets there and will do so again.
    08-31-2014 10:16 PM
  4. Mooncatt's Avatar
    I coined a term called refurbish roulette. I've had a bad track record with getting refurbished phones (including Samsung, but also others) that had defects right out of the box. I've also seen others on here started using the term too when questioning if they should do warranty exchanges due to the risk of getting bad refurbished units in return. I know you're looking at tablets and buying refurbished at retail, but I'm sure they go through the same processes at the same facilities as the phone exchanges. When it comes to electronics, I'll only buy new due to my past experience and that of others I've seen.
    08-31-2014 11:46 PM
  5. barth2's Avatar
    It's kind of luck of the draw really. They always say refurbished go through rigorous testing, but who knows what that involves. Could be just flashing on stock ROM, visual inspection for damage, then power on. It's alive! Pack it, ship it.
    09-01-2014 01:08 PM
  6. Slashyou's Avatar
    thier sometimes even better then new as its tested and stuff.
    srkmagnus likes this.
    09-02-2014 08:41 AM
  1. Replies: 13
    Last Post: 09-05-2014, 06:55 PM
  2. System update on non-nexus tablets, is it free?
    By preppystud in forum General Help and How To
    Last Post: 08-31-2014, 07:44 PM
  3. Replies: 1
    Last Post: 08-31-2014, 07:12 PM
  4. Bolt tablet by nimbus
    Last Post: 08-31-2014, 06:32 PM
  5. SPen issue with only part of screen
    By SA8787 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 08-31-2014, 12:10 PM
