My apologies if this is in the wrong forum.
I am looking at setting up a password manager. However I want one that uses 2 factor authentication to store the master password. Do you know if mSecure uses 2 factor the master password?
For those who use a different product, which ones support 2 factor? I have searched on the web and found only a couple and cannot get a straight answer about mSecure.
Thanks
Thanks
