How to uninstall apps?
tinker1234
72
Android 4.4 KitKat
LG Volt
Virgin Mobile
Hi,
I installed a few apps from the Google play store. Holding my finger down on the image and pressing "remove" doesn't uninstall the app. How can I do that?
Is it also possible to uninstall apps that came with the phone?
Thanks either way
Steve
Javier P
Ambassador
Feb 21, 2014
19,480
3
That action just delete the shortcut for your app. To uninstall an app go to settings > apps > select the app scrolling down > uninstall.
Apps downloaded for you will be in the first tab, for others apps you should swipe to the all tab.
Some apps that come with the phone can't be uninstalled just disabled. The process to do that is the same. Bloatware and Google apps are in this category. Don't get wild disabling, some apps could cause problems in your phone when disabled. If so, enable them back and things will be OK again.
dougdraws
214
You can also install CCleaner for your phone and use that to uninstall apps. I've been using CCleaner on my PC for a long time and it's always done a great job of cleaning the system and uninstalling programs. It works just as great on the Android system, too.
hallux
Q&A Team
Jul 7, 2013
12,322
7
38
If you're in the app drawer you can also uninstall apps from there. Long-press on the app and drag it to the uninstall label.
