Why am I having navigation problems after an OS update?
vinod_naidu
i have a problem with navigation.
model- lenovo s820.
i recently updated my mobile to kitkat but i had a lot of issues with it so i downgraded it back to its base version 4.2.1 from the service center. and now the navigation is not working properly.
when i open the navigation and search for a direction, it loads the route correctly. and the blue arrow(that navigation icon) is also placed in the right place where i am. but as i start moving, the blue navigation icon does not move. it remains constant. what could be the problem.?
i tried reinstalling the maps, made a factory reset too. no use.
any solution?
thank you. :)
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Re: i have a problem with navigation.
Install GPS Status. Then you'll be able to see what the GPS receiver is doing. That will tell you whether it's the GPS firmware that's bad (the phone has to be reflashed) or the navigation app is bad (uninstall it and download it from the Play Store again).
unirockers
