K kjay2559 Active member Oct 18, 2010 34 1 0 Visit site Nov 14, 2010 #1 dumb question, but does the mt 3g support live wallpaper, can't find it on the user manual anywhere. thanks in advance
kinster02 Well-known member Apr 21, 2010 969 47 0 Visit site Nov 14, 2010 #2 Yes, the my touch 3g supports live wallpaper. Last edited: Nov 14, 2010
K kjay2559 Active member Oct 18, 2010 34 1 0 Visit site Nov 15, 2010 #3 Thank you so much kinster02 have a great day :>]
K kjay2559 Active member Oct 18, 2010 34 1 0 Visit site Nov 18, 2010 #4 I have been doing some research and the fact that my OS is only 1.6 and waiting for the said update, I cannot run live wallpapers, so come on Mr update hurry the he*^ up with my notification Please thanks for listening
igotsanevo4g Retired Moderator Jul 31, 2010 3,396 601 113 Visit site Nov 19, 2010 #5 If you root your mt3g you can install 2.2.1 That'd what I suggest, root, then install cyanogen.
