HELP!! How to fix bootloop ZTE AWE N800
About a week ago I downloaded 3D CHAINFIRE on google play hoping i can get better performance in some games, but it told me to install some drivers. I downloaded the drivers, but when it reboot it just got stuck on the android logo and will slowly fade and be filled with very small black lines and the entire screen is a grey.
I tried taking out the battery, go to recovery mode and wiping both data and cache (factory reset), and even try to use the stock rom through ADB Sideload, but nothing it just gets stuck on the android and start to fade. If there something else I can try please let me know!
Also if somebody could give me the stock rom for the zte awe 4.1.2 jellybean , im not sure if this rom is legit or not, when installing the rom it would say the "installation has aborted" and no errors above that.
I'm really new to all this
