How do I Setup Tasker & Secure Settings to Disable Lockscreen When BT is On
shawn.selig29
14
hi guys and gals, im trying to setup tasker and secure settings to disable my lockscreen when my bluetooth is on, and to re enable my lockscreen when my bluetooth is turned off (i dont mind toggling my bt on and off manually via quick settings)
does anyone have any profiles i can download? i tried browsing threw the program to see what i need to do, but i couldnt figure it out.
help is greatly appreciated!
Cheers!
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
on entry:
Secure Settings: Clear Password
Secure Settings: Keyguard Disabled
(I also do)
Secure Settings: USB Debugging Enabled
Mobile Data: Off
On exit:
Secure Settings: Keuguard Enabled
Secure Settings: Set Pin (or password)
Mobile Data: On
Secure Settings: USB Debugging Disabled
You can also change screen timeout, volumes, etc.
