Can not select Phone Contacts source Nissan Altima 2013 Samsung Galaxy 3
I have had no problem with my contacts syncing since I bought the car. Now the other day I can not see the contacts in my phonebook in my car. It looks like it is defaulting to SIM CARD and that is not where the contacts are located. The option to change the contacts source is greyed out. I tried to copy them to the SIM Card and can see some of my contacts but if there are multiple numbers associated with a person I no longer have the option to chose them it seems as it just uses the default. I can go in and sync the contacts and it says they are copying over they don't show up because they are located in a different source other than the SIM. I have tried to delete the Paring on the Phone and the Car and reconnect them but it is still the same.
