"Nebula" Tablet no longer starting
My son's tablet will no longer start up. It is a generic Chinese tablet, but I have the box, manual etc to provide what limited info there is, if needed.
The box has "Nebula 1701" on it and has a picture of the Starship Enterprise .
Some of the Spec:
7 Inch
800x480 display
Dual Core 1.6Ghz
512MB DDR3
Mail-400 GPU
The problem is when the tablet is turned on, it shows the Nebula splash screen as always but instead of proceeding to the Android logo and then the desktop, it just shows the Nebula logo forever. We left it to fully discharge on that screen and it never proceeded further. It will also not turn off in this state, if I hold the power button for about 10 seconds the screen goes off, but when I release it, it comes back on immediately, back at the Nebula logo.
If I plug it into the mains, holding the power button will turn it off and I can see the charging icon as normal, but if you turn it on, again, it will hang.
The machine only has 3 buttons - standby, vol + and vol - and I have tried starting it with every permutation possible and nothing is any different. I am officially out of ideas
Thanks.
Some of the Spec:
7 Inch
800x480 display
Dual Core 1.6Ghz
512MB DDR3
Mail-400 GPU
Thanks.
