Problems with Encrypting SD Card
Phone: Verizon Samsung Galaxy S4
Android: 4.4.2
SD Card: SAMSUNG Plus 32GB Micro SDHC Class 10 Flash Card Model MB-MPBGC/AM
Problem: I cannot seem to encrypt my SD card. If I format the card and have 0 files on it, and then start the encryption process, it will either say "Encrypting SD card..." with no progress meter, or "Encrypting SD card: 0%". It will just stay at 0% forever.
If I put files on the card and then start the encryption process, the progress meter will reach either 65% or 99%, and then be stuck there forever. I've left the phone on for 2 full days on my charger while it was at 99%, and it just remained stuck and never finished.
For reference, I'm using "Settings > More > Security > Encrypt external SD card". I've tried factory resetting my phone, doesn't make a difference. The SD card works fine without encryption, both on the phone and in Windows. I've done a chkdsk on it and the card was fine. Any help would be greatly appreciated.
Android: 4.4.2
