I have downloaded ringtones and want to delete them. For the life of my I cannot figure out how to delete the ringtones. I have tried in the the Music folder and in Settings. I can't find the files.
Chances are they are on your SD card. Try connecting your device to your computer, mounting the SD card and removing them using your computer. Check for them in your Music folder on your SD card first, and if they're not there you should have a folder titled "Notifications" on your SD card, check for them in there.
