Hello, I bought a Voto X2 and start to search rom with bulgarian language. He is same as Umi X2 and i install some Umi roms with original recovery (Android System Recovery 3e), but now i'm stuck on the "miui_umix2_4.8.29_4.2.zip". If i try to install other rom with "apply update from sd card" get a message "--Install /sd card ..." and then "Installation aborted." I try to instal CWM recovery with Mobileuncle Tool, but nothing happening - when I restart to recovery menu see an old recovery and same problem. I don't remember how was before, but now when i start recovery on the screen has android robot with open hood and message "no command" and when i press the power button - enter to recovery. The smartphone is fabric rooted (check with Root checker). I trying with SP Flash tool and MTK droid tools but same sh*t... In same time when I start smartphone everything is ok and no problem to work with him.
Do you have any ideas?
Thanks in advance
Thanks in advance
