What is the best comprehensive backup solution for Note 4?
srechatt
9
Looking for the most comprehensive backup solution for Note 4
I'm probably going to get a replacement for my defective Note 4 (another Note 4) and I am looking for the most comprehensive backup solution that will come closest to putting my new phone in the same condition as my existing phone. I already know that the Samsung solution is very hit or miss on what it restores so has anybody used anything that gets close to reinstalling everything as close as possible to the existing conditions of my phone including settings, apps, etc. Thanks
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
Re: Looking for the most comprehensive backup solution for Note 4
Try using Samsung' solution as well as others, such as Helium, which can backup apps+data. There are also other apps to backup texts and calls.
Let us know how it goes.
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
I have all my contacts on Google, so no problem there. I use App Backup & Restore for apps, Helium for data and SMS Backup & Restore for texts.
If you want to be adventurous, you could flash a custom recovery, do a complete backup, then flash the stock recovery back. then go the other way with the new phone. (I run Safestrap with my Note 3, and always keep a current ROM backup, as well as all the others.)
Laila Nance
