Store to Google Contacts Not Available
The option to save a contact to Gamil/Google Contacts is not available on the People/Contact app on the phone.
Screenshot: i.imgur.com/G9z5WUT.jpg
Google Contacts also does not show up in the phone. I do have a Google Account added. The sync appears to complete successfully and contacts are in "My Contacts" on Google Contact/Gmail. I do have "Show All Contacts" selected in the People/Contact app but only sim contacts are shown there.
Screenshot: i.imgur.com/JxoAxLh.jpg
If I tap on “Add new account” in “Store Contact to”, I believe it brings up the add exchange account, which doesn’t work anyways.
Screenshot: i.imgur.com/sI58G3k.jpg
I have tried to remove - re add the google contact and factory reset the phone several times with no luck. Also tried adding another google account and it acted same for it. Note that the phone does not present any setup wizard after a factory reset. I have to go to settings to add the google account manually.
Here is my phone info:
Android 4.4.2
Brand: Walton
Model: Primo EF2
(It's a local brand in Bangladesh. They basically re-brand sets from Chaina)
About Phone Screen: i.imgur.com/65rY3Iq.png
How can I fix the issue and properly sync the contacts with google contact? Thanks in advance.
Android 4.4.2
Brand: Walton
Model: Primo EF2
