Ive read so many things, like:
-let it almost fully discharge then charge to 100%
-li-ion batteries do best if you charge to roughly 80% and only let drain until 40%
-keep it at 100% charge as much as possible, never let it drain
-li-ion dont like to be at 100%
-they do have memory, and they dont
Whats the best thing to do??
depending on my usage, i can get 2 days out of it, but if i use it more often, ill make it one day (till it gets around 30-40%, which ive read is when its time to charge).
Some people leave them plugged in overnight, others unplug as soon as fully charged.
ive read that trickle charge inst possible - is that true??
What do you all do?
ETA: Ive also found a screen dimmer app, whcih lets me dim the screen beyond factory settings, but this uses ram. so am i better off with a bit less ram or dimmer pixels?
What do you all do?
