Do I use the google Play store app to find packages of rings tones or where do I download them ? or do I download packages online with PC and then xfer them to the phone with a USB wire ? Thanks
If you have the app ES File Explorer you can turn any song on your phone into a ring tone. Open the song with ES click on the menu button and say Set as Ring Tone. BTW it's a free app,.
I use Zedge for that and wallpapers, though I use my phone in a corporate environment around high-level execs so anything other than a normal ring there would be distasteful. I played around with an alternate ring but it was too quiet on even the loudest volume.
