Battery Drain: Why does "Google Services" check my precise location every time I unlock my phone?
forthewin11
8
Hello,
I own a Nexus 4 running Android 5.0 (rooted). In the past week, I have noticed that Google Services is draining my battery pretty quickly because it keeps checking my precise location (using the GPS). Only today have I realized that this position-checking happens only when I unlock my phone, leading me to think this has to do with the Smart Lock trusted places feature.
However, trusted places is turned off (trusted face is on though), so I don't understand why Google Services checks my location every time I unlock my phone. I've had lollipop for almost a month, but I have not had this GPS problem until just a week ago... my phone's GPS would almost never turn on, and Google Services definately did not check my GPS every time I try to unlock my phone. I don't think i've changed any Google Settings either.
Any way to change this (without having to put my location settings in battery saving mode)?
Thanks in advance!
Blodhgard
8
Re: Battery Drain: Why does "Google Services" check my precise location every time I unlock my phone
Try to deactivate the location reporting.
Settings -> Location -> Google Location Reporting and deactivate the location reporting.
forthewin11
8
Nope that did not work... phone still checks location everytime I unlock :(
forthewin11
8
Problem still occurring... I have just turned off GPS on my phone
HoLfElDeR
Active member
Dec 10, 2011
28
Settings-Security-Trust Agents and Toggle Off SmartLock (google). That's if you don't plan to use trusted places and it should get rid of the location on unlock.
Try this
forthewin11
8
Try this
Thank you! This works perfectly, and I can now keep my GPS setting on without the battery draining every time I turn on my phone :)
LarsErikOsterud
But if you turn off "Smart Lock" then you also loose the ability to skip lock-screen for Bluetooth connections :-(
I use "Smart Lock" to disable the fingerprint check when connected to my handsfree in my car.
I have no GPS positions registered with "Smart Lock" so why should it check my position then.
This is at the best a completly terrible written code :-(
forthewin11
8
Completely agree... Don't have any GPS positions, but it still checks my location. It sucks because I cannot use trusted face with it disabled.
Oh well, nothing much we could do I guess.
pauloxcavalcante
