re: a problem with re-booting a zte warp 4g n9510
I had to dump my ZTE Warp 4g n9510 cell phone back to factory default because a hacker got into it (everything on the phone, games, contacts list and so on is backed up on on a windows cd-disk, before the hacker hit it. I learned that lesson the hard way). On the advice from Boost Mobile I did a "##786# then it asked for a MSL password. The phone is back to the way it was when I got it brand spanking new. I found the instructions for Framaroot at click here for link I followed the instructions and when I click on "Aragorn" or "Gandalf" I get the following error messages bellow.
Aragorn
Failed :-(...try another exploit if available (error #6)
Gandalf
Failed :-(...try another exploit if available (error #5)
What gives? I followed the instructions. What does the error numbers mean? I can't find any reference to error numbers 5 and 6. I can do a screen capture and past if need be. I must be doing something wrong or out of sequence. I could use some help please.
Steve
Aragorn
Gandalf
Steve
