Remove "Tap and hold this screen to add apps and widgets"?
msbadger
LG Enact here. I've seen threads similar to this, but pertaining to the S3. The popular consensus (add an app and then remove it) does not work for this phone; if there is no app/widget on the page, I get an annoying sentence prompt.
Is there any way to disable this, or to trick it? Like having a transparent icon for an app with no label?
Thanks in advance.
Pic related: i(dot)imgur(dot)com/4gsB0CF(dot)png
