Phone: LG Spectrum
ROM: Cyanogen 10.1 3 or something
So I was in the process of manually installing CWM Touch via Rashr Flash Tool, and when I successfully got it installed, the app asked if I wanted to reboot into recovery. So I pressed yes, and it did.
Unfortunately, whatever that app wrote into the androids system, it never seemed to remove it afterwards because after every single reboot, it kept going back to recovery, not loading the android OS. Even when I explicitly chose "reboot to bootloader" in CWM, it would still reboot to recovery. I've even went to a totally stock restore, and it still kept happening. Cleared cache, data, davik cache, same result. What can I do? :-\
I currently have 2 restores. One of cyanogen, where i used Rashr's tool, and the other a V6 stock restore.
