Can I use other 3rd party (not from samsung) USB wire (the wire connect to PC and phone) with my samsung S4 phone?
Are all USB wire the same?
The USB cable themselves should be interchangeable for charging, although this doesn't account for the possibility of poor build quality or materials in a cheap cable. Data transfer usually works as well, but I have encountered some variability with that, and have read some posts about it as well. Remember, we're talking about the cables here, not the wall plug. Different wall plugs may provide different max amperage, which means some chargers may charge slower than others.
BTW, Mooncatt, where have you seen microUSB-USB data only cables? I'd love to transfer data without being forced to charge without having to cut a cable up.. When my battery is at 90%, and on the discharge part of the cycle, I don't want to mess up the cycle by charging it for 10 minutes. (I have loads of charge-only cables and tons of 4 wire cables, but I've never seen a data only one.)
Well ...The good news is lithium batteries aren't affected by short cycles. Charging a battery from 50% to full is effectively a half cycle. In theory, two 50% charges have the same effect on lifespan as one full cycle charge. Of course with the other variables, it's hard to say just how little it'd affect lifespan. I doubt it's enough to matter a ton.
