I need to open a same app twice, e.g. I want to open 2 maps (or 2 gallery images), so I can use the switch task button (long press home key) to quickly switch between 2 maps (or 2 images).
How to open the same app twice?
I am using Samsung S4
One some apps are available in the multi window sidebar (I already pressed the edit button, the app is not inside there). Is there a way to add more apps that are not shown inside multi window sidebar and edit button?
I want display/open 2 same apps e.g. 2 Google maps (or 2 gallery images), so I can view 2 maps at the same time side by side on the screen in 2 multi window.
How to do that? Thanks
