I dropped a bottle on my LG G2 and the left corner of the screen cracked. I checked it out and the touch screen doesn't work anymore. Can this be fixed? If so how and what do i do/need to fix it ?
If the crack damaged the digitizer or the connector, that's what you'd need to replace. Glass and digitizer. But unless you're really savvy on this kind of repairwork, I strongly suggest you let a service center do it for you (plus, if they screw that up, they're responsible, not you)
