Android Forums at AndroidCentral.com >  Android Chat >  General Help and How To > Please insert an SD card before using the camera...
    Thread Author   #1
Old 12-09-2010, 10:21 PM
Device(s): Samsung Galaxy Nexus
My Next Device: Better battery life...
Activity: 3/20
Hi, Before we go any further, I do have an SDCARD inserted and mounted :-)
As far as I can see (when its problematic) it can be accessed by some android applications but not by others:
* the Camera gived the message in this post's subject line
* Memento says "Sorry, your SD card is busy"
* J Bench Mark 1.0, successfully writes 10MB to the card
* LauncherPro can make backup of homescreens
If I make it available for "memory card access" it appears to be fine in windows and a chkdsk doesn't detect any issues. It is FAT32 and I have used about 400MB of 8GB.
I've had the phone for the while but these issues only for the last month or so, I seem to need to boot once or twice to get it to work so it could be a software issue with something I installed or the latest Motorola Milestone 2.1 update.
From Log:
12-10 14:14:06.228 D/vold ( 1037): Filesystem check completed OK
12-10 14:14:06.236 I/vold ( 1037): Sucessfully mounted vfat filesystem 179:1 on /sdcard (safe-mode on)
12-10 14:14:06.236 D/MountListener( 1270): handleEvent volume_mounted:/sdcard
12-10 14:14:06.291 D/UsbService( 1359): onReceive(), received intent:android.intent.action.MEDIA_MOUNTED
Is there a required "system" directory that may have gotten corrupt etc?
Any ideas? Thanks for any ideas...
  #2
Old 12-09-2010, 11:06 PM
Device(s): Fascinate / Droid Charge
ROM/Kernel: Altered Beast / Voodoo
My Next Device: Samsung Galaxy S2
Activity: 0/20
From Log:
have you taken the card out checked for dust on the connectors.
perhaps maybe the phone was dropped and somehow the card is not sitting correctly.
Just throwing stuff against the wall....
  #3
Old 12-09-2010, 11:37 PM
Retired Moderator
Device(s): Nexus S 4G/HP Touchpad
ROM/Kernel: Ice Cream Sandwich
My Next Device: Who knows anymore...
Activity: 2/20
Go to your camera app and clear data maybe?
    Thread Author   #4
Old 12-10-2010, 12:47 AM
Activity: 3/20
Quote:
Thanks, clearing camera data didn't make a difference but will clear again and reboot and see if it occurs again.
  #5
Old 12-10-2010, 08:43 PM
Activity: 0/20
Could also be a defective card. Have you tried any others?
    Thread Author   #6
Old 12-10-2010, 09:42 PM
Activity: 3/20
Quote:
No, don't have other cards but J Bench Mark 1.0, successfully writes 10MB to the card, and a reboot "fixes"
    Thread Author   #7
Old 01-28-2011, 08:15 PM
Activity: 3/20
To early to say but reasonably sure that this will have fixed it: [Only registered users can view links. ]
Reply
Tags
access , camera , sd card , sdcard
Thread Tools Search this Thread
Search this Thread:
Advanced Search
