Results 1 to 7 of 7
- 12-10-2010, 10:01 AM
Thread Author #1
- 12-10-2010, 10:06 AM #2
I have the same gmail account on two phones and it works great! Haven't tried the other apps.
- 12-10-2010, 10:32 AM #3
Part of the beauty of Android is that you can do just that. I believe even your paid apps are available on both devices.
- 12-10-2010, 12:10 PM
Thread Author #4
- 12-10-2010, 02:30 PM #5
- 02-01-2011, 08:30 AM #6
- 02-01-2011, 10:17 AM #7
Once you get your new phone, it will sync up with it for the first time and from there but will not erase your gmail contacts. You can always go to your gmail and export everything before you do it just incase.
-Droid RAZR MAXX (Artic 2.2)
-Motorola Xoom (Rooted/Unlocked ICS)
-VZW 4510L LTE MiFi
Reply
