Galaxy S3 battery indicator doesn't change
Chance Brown
I recently was given a Galaxy S3 from a good friend of mine because I was in dire need of an android device. I had an IPhone 5 and absolutely had the thing. He told me he had a problem with the battery indicator not being accurate but that didn't matter much. I went to Verizon and had them switch the phones over and now I have found that the inaccuracy is becoming a problem. The issue is the indicator never moves off 100%. I can use the phone until the battery dies and when I put it on the charger it says it is charging with 100% battery. I take it off the charger a few hours later and use it for a few hours look at the indicator it says that the battery is 100%. So basically the indicator doesn't fluctuate with the battery. Does anyone know what is going on with this?
P.S. My buddy said the phone has done this since he updated to 4.4.2. Also He and I both did a factory reset with no solution. I did the battery spin test and the battery seems fine.
