Results 1 to 5 of 5
    OGCF's Avatar
    Posts
    Global Posts
    11 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Best Place to Buy a Phone Using Another's Upgrade?
    Hey everyone, I'm with AT&T right now and the primary line on my account has an upgrade available. I know AT&T allows you to use another person's upgrade for yourself so I was just wondering which website would be best to get an upgrade from?
    I tried Wirefly recently because of their stupidly cheap deals, but their six month contract prevents you from using the phone with a different line so that didn't work out. Any others? Also, does anyone know if AT&T price matches?
    Thanks!
  2. #2
    ls377's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Teamhacksung's ICS
    Default
    They should match the price if you can't use your upgrade on another site at all (I couldn't buy through Amazon due to a corporate discount on my line, so they matched the price), but I'm not sure they would in your case.
    OGCF's Avatar
    Posts
    Global Posts
    11 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by ls377 View Post
    Well I figured AT&T wouldn't price match to online stores. But could I still price match to Walmart or Radioshack or Best Buy's in-store prices?
  4. #4
    ls377's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Teamhacksung's ICS
    Default
    Quote Originally Posted by OGCF View Post
    I doubt it, but the best thing is to ask AT&T, or even see if those stores can do what you want to do.
  5. #5
    blopez24's Avatar
    Posts
    Global Posts
    811 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I found the only way to do that is through AT&T. I couldnt do it with anyone else when i tried to do it last year using my brothers upgrade.
