Save Game (Candy Crush) Level to Computer or SD Card
How do I save game data to my computer or to an SD card from a Galaxy S4? Thanks,
You can use Helium:
https://forums.androidcentral.com/e...ils?id=com.koushikdutta.backup&token=wOhnmIx8
It involves installing the app as well as drivers on your PC, but it works.
That's the only one I've ever tried.
You might have to change your storage settings....go into settings/storage and hit the 3 dots menu button and see if your phone is set to PTP or MTP....one is just for photos and the other for is media....you want the MTP. There's several tutorials you can find around the web as well.
