My Droid just loves to soft reset itself! (Problem solved, please lock)
It's done so about 5 times in the 45 minutes. This only started happening after one of my app's recent updates. Also, whenever I scan it with a virus scanner it restarts.
Anyone have the same problem? Help?
I updated four apps at the same time but I currently only remember 2.
Draw and Gdocs.
Edit: Uninstalled Draw and it still reset. Will uninstall Gdocs.
Edit 2: Oh yeah, I also updated Truth or Dare. Uninstalled. Didn't help. I should also note that I am running Home++, very buggy. Constantly force closes. Perhaps its causing the restarting problem.
Draw and Gdocs.
