1. CyD13's Avatar
    It's done so about 5 times in the 45 minutes. This only started happening after one of my app's recent updates. Also, whenever I scan it with a virus scanner it restarts.
    Anyone have the same problem? Help?
    I updated four apps at the same time but I currently only remember 2.
    Draw and Gdocs.
    Edit: Uninstalled Draw and it still reset. Will uninstall Gdocs.
    Edit 2: Oh yeah, I also updated Truth or Dare. Uninstalled. Didn't help. I should also note that I am running Home++, very buggy. Constantly force closes. Perhaps its causing the restarting problem.
    12-31-2009 04:36 PM
  2. pbrennan42's Avatar
    It's the Antivirus Free 1.6.7 - it is seriously FUBAR'd. Uninstall that and you will be fine again.
    All of us have had that problem today.
    Phil.
    12-31-2009 04:39 PM
  3. CyD13's Avatar
    Phil.
    Ha. That was the last item updated. Thanks. I suppose this topic can be locked now.
    Edit: Wow. It just reset itself again. After I uninstalled anti-virus thing. I'm going to hard reset. It was working for a while.
    Edit: Ran a virus scan with Lookout, everything clear.
    Edit 2: It seems to be working. Lock thread please.
    12-31-2009 04:47 PM
  4. pyshnkyrats's Avatar
    I was having the same issue, so I too uninstalled the antivirus software. So far, so good.
    12-31-2009 09:53 PM
