Noob Needs help understanding Compatibility between SDXC UHS-I Card and my LG Lucid 3 VS876
I bought the card in a hurry and was dumb enough to forget that it has to be compatible with my device. Which is scarcely mentioned in any forums. Here is the cards compatibility stats:
About Compatibility
SDXC, SDHC, SD Memory cards and Host Device Compatibility
* SDXC Backwards Compatibility Configuration
* SDXC memory cards can be used only with SDXC host products.
* SDXC host products can use SD, SDHC and SDXC memory cards.
* SDHC memory cards can be used with SDHC and SDXC host products.
* SDHC host products can use both SD and SDHC memory cards.
Backwards capability is a standard, for example a data format in electronics such as video cameras and computers.
A device is backwards compatible if products designed for the new standard can receive, read, view or play older standards and formats. Will this be compatible with the Lucid 3? Compatibility question
~~solved ~~
Found 3 user reviews and one store that one feature was the compatibility between the SDXC UHS 1 and the Lucid 3.
Next, Should I format this fast 30MBs, high capacity card and do we still need the 3 partitions in android since API 19? If so, what size to make partitions and what formats on a 64 GB card?
About Compatibility
~~solved ~~
