How to stop when typing on s4 it double clicks and puts in symbol
Have to make very fast keystrokes to prevent the double click.
Go into your keyboard settings and see if there is a setting for adjusting the long press action. If there isn't, replacement apps such as Swiftkey do allow you to adjust the time for long pressing.Have to make very fast keystrokes to prevent the double click.
