Hello AndroidCentral,
I am having some issues with 2 Asus MeMoPad HD 7's. The problem being that when I try to connect to WiFi i constantly get back "Authentication problems". I have 58 other Memopads that are connecting to the same WiFi just fine however these 2 pads keep giving me the same authentication errors. I have tried taking off the wireless password and they still do not connect. I also have tried connecting it to my phones Wireless Hotspot which works perfectly fine. Does anyone have any ideas as to what i can do to connect these 2 Memopads to the wifi.
Things i have tried:
Connecting to a wireless hotspot
Removing the password to the wireless
Flashed the memopad with a stock ROM
Factory reset the device
wiped the cache
wiped the dalvik cache
made sure i entered the correct wireless password
Is there anything else i can try?
Thanks,
Wivane
Edit: Sorry if this is in the wrong section, if it is can it be moved to the correct section by a moderator.
Edit 2: Please check out this thread on XDA Developers also. forum. xda-developers. com/memo-pad-7/help/asus-memopad-hd-7-me173x-authentication-t3056323#post59497688 Cannot post links due to not having 10 posts!
wiped the cache
Thanks,
Wivane
