Results 1 to 6 of 6
    Default Ringtone management.
    How in the world can I have separate ringtones for people, messages and voicemail? That is all, just got my captivate and its amazing. Thanks to whom helps!
  2. #2
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Default
    Quote Originally Posted by khep24 View Post
    Congrats, great phone and welcome to Android central.
    Go go Contacts, select the contact that you want to change the ringtone, then hit the Menu capacitive button, select edit. scroll down to ringtone
    If i've made life easier buy me a Macchiato
    Default
    Oh Ok Well what about using my own audio for my ringtones? Like different for my calls, messages ect.
  4. #4
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Default
    download a program called Handcent. do the same process as above , but this time it will give you an option, default ringtone, or phone ringtone select phone ringtone, another option popup will come up,, android system and select music,,,choose select music this will bring you into handcent menu current ringtone, system ringtone, music,,,,select music and that will retrieve music from your music folder.
    Default
    Thanks man soo much you avoided me from havin a head ache cause if everything was the same I would go crazy! But thanks again :^)
    Thanked by:
  6. #6
    DroidXcon's Avatar
    Posts
    Global Posts
    11,639 Global Posts
    ROM
    Stock for now
    Default
    anytime glad i could help
