Phone sometimes charges and turns on, most of the time doesn't
I have a galaxy ace 3. Since I have had the phone I have had issIues with charging the phone. I find that if I let the phone run out of battery, i struggle to turn it back on. I plug it in and it shows the charging symbol but when I try to turn it back on, it doent turn on. If i keep trying with this then after 30 or so attempts with this, I can finally get it to charge and turn on. Most of the time it will show charging but when I try to turn it on, the samsung writing comes on, then the phone dies again and stops charging. I am completely stumped with this one as my logic is that if it was the battery it wouldnt turn on at all or wouldnt charge. Thanks in advance for any help or advice you can give
