1. pixelsyndicate's Avatar
    Hey all,
    I am looking to max out the memory on my Droid X. The Android Central store only sells up-to the 16 gig memory card. Anyone have suggestions for a fast 32 gig at a good price? I want to be able to carry loads of movies and audio books on my X.
    thanks!
    12-27-2010 01:59 PM
  2. RUSH's Avatar
    12-27-2010 02:13 PM
  3. Chris Kerrigan's Avatar
    I'd also recommend checking out Newegg. I've found a few at the link below.
    Newegg.com - 32gb micro sd
    12-27-2010 02:19 PM
  4. takeshi's Avatar
    My general approach for anything: use Google Shopping, omit the questionable resellers (use Reseller Ratings and personal buying experiences with vendors). Stick with reputable brands as well as reputable resellers.
    12-28-2010 09:10 AM
  5. Cory Streater's Avatar
    Hey all,
    thanks!
    Check out this thread as well.
    12-28-2010 11:22 AM
