Results 1 to 8 of 8
- 12-28-2010, 09:23 PM
Thread Author #1
Changing default. TouchWiz
Well I did something very careless... I had just downloaded Launcher pro plus and I wanted to keep launcher pro as the default launcher although I pressed set TouchWiz as the default. So no I cant find a way to change it from being the default. How can I change the default?
- 12-28-2010, 09:37 PM
Thread Author #2
Oh nevermind i found how to do it im just soo dang smart!! But all you do is:
Tap the menu button
Then tap settings
after that choose applications
Then choose manage applications
Since TWLauncher isnt a Third party app just tap menu button and tap filter
when you choose filter choose all
Then find TWLauncher and clear default. - 12-28-2010, 09:40 PM #3
- 12-28-2010, 09:49 PM
Thread Author #4
- 12-28-2010, 09:56 PM #5
Glad you got it figured out khep!
New York Giants | New Jersey Devils | Colorado Avalanche | New York Knicks - 12-28-2010, 10:01 PM #6
Just download home switcher its worth it
- 12-28-2010, 10:18 PM
Thread Author #7
- 06-22-2011, 10:44 AM #8
I believe you can also go to Menu | Settings | Applications | Manage Apps | All and then find the app that's your current launcher, tap it, and tap the "Clear Defaults" button. Then tap the Home button and it should ask you which app you want to use and you'll get a list of the available apps that can be used.
Hope that helps!
GeekDrop.com
Reply
